I have a smart lock 3.0 PRO, but I suppose every smart lock will benefit from this?
The smart lock currently can only open with bluethooth when no “remote access” is enabled. This requires the user to connect to bluetooth before opening the door.
The requirement is that if the user is on WiFi it can open the door without “remote access”.
The user can open the door while be in wifi range. Since the user should already have access to the same wifi and have a valid Nuki key this is reasonable on security level.
A friend that will visit home and is on wifi list but I do not want to be able to open the door remotly?
Also avoiding clumsy “open door” while I check if door is closed from away ?
