User specific locking and opening of the door, software update
Nuki Smart Lock (all), via SOFTWARE
when installing a Smart Lock, we can turn 1x, 2x and do changes about the degrees ° of closing
But we can’t set up :
  1. to close, turn the lock 1.45678 times to Left/Right. Or turn from “unlock” 703° to the right or the left.
  2. to open the door: turn x° (1 to 20°?) to the right/left. Or
best would be even to move the desired position and tell the Smart Lock: I want to open/close to there. That is “my” locking or opening position
it’s a few modification of the coding: instead of using Lock “1x or 2x” remove the 1 or 2 by a variable that can be 1.234 or 2.3456 if needed.
less stress on device
less stress on battery /longer battery life
less time needed
and because… it’s way easier to understand then to go to the customized settings and try to understand the four lines of rotation in °
Software can be edited.
Some parts of the menu can be removed
battery / power pack will last longer.
The nuki base plate will have less stress on it, for example when opening and “going to far”.
Especially benefiting the glued base plate.
