Is it possible to use two Nuki Opener on the same intercom/Nuki Bridge? My apartment building have two doors before I get to my apartment door. I have configured the Opener to open the first door, but I still have to use my key on the second door. I have also managed to configure the Opener to open the second door, but both at the same time is not possible .I understand that multiple door is not supported yet (when will it be?), but could installing another Nuki Opener solve the problem?
also interested in the solution, I have also two doors before arriving to my appartement, but that shouldn’t change anything since ringing use the same code why wouldn’t it work ?
What system is rungin in your building? If it is an analogue setup where you have acess to all the wirings you can shortcut the openers and switch them both with one opener. However if you have different users that are not suposed to open both doors at the same time you have to use a relay. Under my user you will find a post that explains more in detail how i solved the problem…
Yes dual door support please ![]()
Thank you for the reply. My intercom is a STR HT40. I don’t know to much about intercoms, is this a analogue setup or can I use a relay as you mention? Please see picture of the wiring with one Opener already connected. If you care to give me some pinpoints to get me started I would be very grateful. Thank you! ![]()
Did you manage to get this done? I also have the STR HT40 and it works great with 1 opener, but I just can’t find out how to wire 2 and still keep it working.
Hi! Have you already tried to connect the second opener just to the same wires as the first one, and it stopped working, or haven’t you tried it yet!?
