Use Nuki Box with Keypad
Hey,
is it actually possible to use the Keypad to open a door that uses the Nuki Box?
If not, would it be a suitable workaround to integrate the Nuki Opener within the Intercom, connect it to a Bridge and use the Keypad to open the door?
Best,
Christoph
No, this is currently not possible.
Yes, that could be a viable option, if you have Wifi and power supply for the Bridge in range. And you also have to keep in mind that the Keypad needs to be in Bluetooth range of the Opener!
Thank you Stephan for the fast reply!
Regarding the keypad - where will the keys be stored? In the Opener like it’s the case with the SL?
Yes, the logic is on the device itself; as for the Smart Lock.
