Hey there!
I am a very newbie to this world and maybe you can help me. Attached you‘ll find my opener connected to Urmet CS1131.
Ring to open does not work ![]()
The function swipe to unlock does work.
What can I do to make it work?
Any ideas? The yellow cable is not connected…
Hi Matthias,
I have the same wiring with the same problem. Did you solve it?
Thx!
no ![]()
still hoping for an answer
Hey,
I found the solution that worked for me today, maybe this one works for you too:
- Nuki Yellow Cable into the Clamb
- Cable connected to RZ into the Clamb
- Nuki Green Cable (which Nuki says should go to CA, even though CA is empty initially) into RZ
With this I have the following result:
- Open via App works
- Ring to open works
- Open via Nuki Opener button works
- Open via old opening button works
Maybe this helps you or anyone else facing the same issue
