Urgent Feedback: Addressing Persistent Issues with Firmware Stability, Debugging, and Support
Dear Nuki Developer Team and Community,
I am writing to express significant concerns regarding the current state of Nuki firmware, the lack of effective debugging tools for users, and the responsiveness of the support system. As a user invested in the Nuki ecosystem, I believe it’s crucial to highlight these issues to foster improvement and ensure the long-term reliability and usability of Nuki products.
The core of my frustration lies with the Nuki firmware, which, in my experience, has been extremely buggy across both stable and beta releases. This instability manifests in various ways, leading to a degraded user experience and a lack of confidence in the system’s reliability.
Compounding this issue is the absence of useful debugging output. When problems arise, users are left without clear indicators or logs to help diagnose the source of the issue. This makes troubleshooting a guessing game and hinders the ability of technically proficient users to provide detailed feedback or find workarounds.
My interactions with Nuki support have unfortunately not alleviated these concerns. Responses are often slow and tend to be evasive. The standard suggestion to perform a factory reset is frequently offered as a catch-all solution, which is not only disruptive but also fails to address underlying firmware or hardware issues, especially when problems reoccur shortly after.
I am currently experiencing several specific, critical problems:
  1. Keypad 2 Fingerprint Malfunction: While PIN code entry on my Keypad 2 continues to work flawlessly, the fingerprint sensor has ceased to function. This feature was working correctly initially. Now, attempting to use a registered fingerprint results in the Keypad 2 LED blinking 6 or 7 times, with no successful authentication. This regression in a key feature is particularly concerning.
  2. Nuki Wi-Fi Connectivity Problems: Despite ensuring my Nuki device is connected to a dedicated 2.4GHz WLAN network with a strong signal and correct credentials, the Nuki app persistently reports “not connected to server” or indicates “no internet,” even when the device clearly has a local network connection. Interestingly, invoking the network status by pressing the Nuki bridge/device button (relevant procedure for displaying network info, e.g., 7 times for some models) correctly displays the assigned IP address and default gateway, confirming its connection to the local network. This suggests an issue with the device’s communication to Nuki’s backend servers, despite a valid local Wi-Fi link.
These recurring issues, where functionalities that previously worked reliably suddenly fail, are extremely annoying. It fosters a sentiment that customers and their reported problems are not being taken seriously, and that the quality assurance for updates may not be as rigorous as one would hope.
We, as users and potentially developers relying on your platform, need:
  • More stable firmware releases.
  • Meaningful debugging information accessible to users to help identify issues.
  • Responsive and technically proficient support that goes beyond generic troubleshooting steps.
  • Transparent communication regarding known bugs and expected timelines for fixes.
I urge the Nuki team to address these points with the seriousness they deserve. The innovation Nuki brings to smart access is commendable, but the reliability and support must match this innovation to maintain user trust and satisfaction.
I am open to providing further specific details and logs if a mechanism to capture relevant information can be provided.
Thank you for your time and consideration. Feel free to upvote this for more visibility!
Sincerely,
Stephan
Also encountering the “not connected to server” problem with my Smartlock Pro 4 over Wi-Fi. This issue began a month or so ago, unexpectedly, as the lock had been functioning perfectly and there have been no alterations to my Wi-Fi access point location or settings.
I’m wondering if this problem stems from an upgrade to Beta firmware version 4.7.0, but I’m unable to tell which firmware version was active when the lock was working correctly. The constant reliance on Bluetooth for control, due to the Wi-Fi disconnects, is very inconvenient. Unfortunately, a factory reset hasn’t fixed the issue.
Is there a way to do a firmware downgrade?
The problem is that Nuki team will normally hide you post because it goes against there policy. Yes no free speech/opinion.
We were like you wanting to make Nuki a real good solution without the flaws that were developed at site with us all beta users (see battery vs usb-C, locking path, software requirements for Airbnb integration and many more).
So we will learn. No worries… that post will be hidden (censorship)
Best wishes to all
I can confirm the issue with the Keypad 2 that the fingerprints are no longer working.
have you tried the support suggestions e.g. resetting keypad to factory defaults etc. did the fingerprints start working again? I presume code is still working (same for me here)
I hope they understand that I made this post to help and to show the issues that matter to the community
Sorry guys, but this is not a customer support forum. Please contact customer support through the Nuki App if you have a problem. Thank you!
I had that hope too. But it was not so.
And as you see… it’s not customer support: customer support is by phone email and can’t be share. So not perfect experience will not be shared.
Our post about development and trouble solution due to the base plate was hidden: even we provided a solution that could be implemented through beta users/developpers/nerdies and with the next generation of base plate.
I assume your post (and especially ours) will be hidden soon as critic is not tolerated in an authoritarian (yes, an admin confirmed that wording) platform.
Edit: maybe we were wrong : it’s not a community…. Which is as well to be seen because the topic will be closed soon after last comment
