After years of using a Nuki Pro 2.0 with a Bridge and integrating the Lock via the HTTP-API in my KNX System , I recently switched to a Nuki Ultra which doesn’t support the Bride and therefore the Bridge API anymore. After fiddling around I finally managed to integrate the lock via HTTPS-Request and API Token as the authentication mechanism. But according to the API documentation this feature (API Tokens) will be shut down (sunset) in the feature. Is there a timeframe when this will happen, and will there be an easy and convenient way for authentication after this - OAuth2 seems to be a bit overkill for a non developer like me.
