my Nuki lock started to act strange. When I unlock the door it also holds the latch for 1s.
Lock settings:
door fitting: Lever
Unlatch duration: 1s (Can’t disable that even if “Lever” door fitting is selected ?!)
That never happened before. Did you break something with the latest update?
Looks like the lock lost its position and therefore went too far when opening the door. This is usually an individual problem which needs analysis of the logfiles/protocol to identify the root cause (if this is possible at all). Make sure to use the latest firmware.
No. Unlatch is always there as a function, but somehow hidden in the bottom sheet of the App as it needs a second swipe up when you set the Smart Lock to have a handle at the outside of your door.
The unlatch function could proove helpful in case you ever have problems with position loss or malfunction of the Smart Lock as it does not rely on the internal position sensing of the Smart Lock and drives the motor against it hits the “end” in the unlock direction.
My door is not totally balanced, so if unlock is followed by unlatch, the door stays open and doesn’t lock back successfully on it’s own.
When entering the house from the front door, which doesn’t have Nuki installed to it, the side door is auto unlocked and gets open as well…
