Since installing the new firmware 1.10.3 on the Nuki SL 1.0, the measured temperature is no longer correct. Displays 25C instead of 17C. Is that known?
sorry for the late reply. I’ve forwarded your report to our support team. Thank you for getting in touch!
the battery pack had probably heated up when the battery pack was changed. now the temperatures are right again…
Thank you for you feedback!
Which type of batteries are you using? Or did you use when having the issue with the low temperature?
Eneloop (black)
