Hey people,
I have used code generation tools to generate code from your swagger.json (https://api.nuki.io/static/swagger/swagger.json).
I noticed at least one syntax error. In account/user.get, you use “int” for offset and limit, but it should be “integer”.
Also there is at least another error where the actual behavior differs from the swagger.json. There is this definition called ObjectId. It has several properties. But in the actual API, it is just a string. That would break auto generated clients. I didn’t notice at first because the property is often omitted and only present when you just made an update to a resource. So I noticed too late in production.
It would be nice, especially for people starting new integrations, to have those problems fixed upstream.
If anyone should run into the same problem, I build a workaround in nupin/Makefile at 1a4e322712cffa52c0e60093c4ba57719c607d97 · leonnicolas/nupin · GitHub. I fixed the “int” with a sed and the ObjectId problem with a json patch. In this project, I only use two endpoints of the web API, so maybe there are more issues.
