Support for Golmar G2+ BUS system
Anyone has experience with installing the Opener for a Golmar G2+ BUS system (Art 4Lite)?
I have tried the Generic schema without success.
I’m looking for the same solution
I’m also interested on this
Hi guys, any update here?
thanks
Hi all,
Did someone had luck with integrating G2+ bus from Golmar into the opener?
I moved to a different house and I have the same Art 4 Lite terminal as the OP.
Maybe @Georg_S can help ?
Thanks in advance!
It will be very appreciated because it does not seems to be a compatible with your golmar plus solutions
I have contacted Golmar (Evicom in France) and it’s not possible to communicate with G2+ BUS officialy, we need to retro engineer the communication.
Hi
Is there maybe an update on this? This would be my last try to find an answer or look for a different system.
Kind regards
Bernard
My property just switched to Golmar G2+ System… So I have thé samevissue as you.
I need it to work with Nuki Opener.
How can I achieve that ?
Thanks for your help
