I’m trying to connect my opener with a STR WF32 . . .
According to the Support I need to connect the blue cable to pin2 and the purple one to pin 3.
Between the pins I have 20V. If I open directly with the STR32 it goes down to ~9V (and the door opens)
If I open in the app the voltage goes down to zero but the door doesn’t open.
Hello.
Nice to read. I have the same issue, it’s not working.
I’m quite sure there is something wrong or missing in this.
For example, if I put the speaker on, the only way to stop it directly is to use the unlock button.
But when I open via Nuki, the speaker stops but come back. And door never open.
Also, I had the ring on the app only once…
Since months I’m trying things but nothing.
