http://192.168.178.44:8080/lockState?nukiId=xxxxxxx&token=yyyyyy returns:
HTTP 404 Not Found
List returns (door locked):
[{“deviceType”: 0, “nukiId”: xxxxxxx, “name”: “np5ht”, “firmwareVersion”: “2.5.1”, “lastKnownState”: {“mode”: 2, “state”: 3, “stateName”: “unlocked”, “batteryCritical”: false, “timestamp”: “2019-06-13T17:30:06+00:00”}}]
Timestamp is not correct either, even assuming that is seems to be 2 hours behind CEDT currently.
Callback isn’t issued either to my homematic, so state in homematic is wrong.
The app on my iphone (latest beta) shows no connection between Server-Bridge-Nuki. Connection between iphone and Server is green.
Once I used the app and issue /list, then the result is correct
[{“deviceType”: 0, “nukiId”: xxxxxxx, “name”: “np5ht”, “firmwareVersion”: “2.5.1”, “lastKnownState”: {“mode”: 2, “state”: 1, “stateName”: “locked”, “batteryCritical”: false, “timestamp”: “2019-06-13T20:13:43+00:00”}}]
(timestamp is 2 hours after CEDT, but it shows the time when I used the app, not the time when I closed the lock)
/lockState still doesn’t work.
Callback to homematic is issued, so state in homematic is correct.
The app on my iphone (latest beta) shows still no connection between Server-Bridge-Nuki.
/info displays
{“bridgeType”: 1, “ids”: {“hardwareId”: xxxxxxx, “serverId”: xxxxxxxx}, “versions”: {“firmwareVersion”: “1.12.6”, “wifiFirmwareVersion”: “1.2.0”}, “uptime”: 1080480, “currentTime”: “2019-06-13T20:21:56+00:00”, “serverConnected”: true, “scanResults”: [{“deviceType”: 0, “nukiId”: xxxxxxxx, “name”: “xxxxxxxx”, “rssi”: -56, “paired”: true}]}
Currently I have 2.52 SL waiting, but no time to install tonight. Should that solve the problem?
