Is there any config to leave the door always open and with the lock IN? I want to leave the door open and the autolock does not work as well as the Lock’n’go. Is it possible?
No. Holding the latch draws constant current from the batteries for the motor, which would deplete them quickly.
Thx for replying. And if just keep the latch bolt out but the deadbolt in. Would that work ok?
That’s the normal “unlocked” position (Deadbolt is in and latch is out). Lock stays in that position until you lock it again.
Sorry fir bothering you again but I do not know how to configure like that. It always lock with deadbolt after auto unlock
Please contact our support via https://nuki.io/en/support-request/ or contact@nuki.io.
I can’t help you at this stage anymore because this forum is focused on developer related issues.
