I don’t find the right connections for connecting the umet 1740/90 with the smart opener. The umet 1740 signo listed in the app has not the same connections!
I tried some other umet description but the ringtone mute or often the opening is not working correctly
Schematic.
6,10 are used for negative as I see it. I would try putting the purple in 10 if its not too late
Did you find a solution? I have the same model and I also can’t install
I made it work:
Quick question on that - how do you power your Nuki in this setup? Does one of the wires on the original panel provides the current or are you using an external power source?
I use it with battery
