Smart Lock Ultra
What’s New?
Built without compromises for a new powerful experience: Ultra is the fastest and smallest Nuki Smart Lock with a brand-new motor and design.
New Motor
Nuki Smart Lock Ultra is the fastest and smallest smart lock developed by Nuki. Ultra is three times faster and only a third of the size of previous generations, thanks to its brand new motor.
For the first time, Nuki Smart Lock Ultra gives you direct control over the locking speed of your door with 3 new modes:
  • Insane: Maximum speed
  • Standard: Balanced speed (default setting)
  • Gentle: Reduced noise with lower speed
Design
Nuki Ultra combines cutting-edge performance with a striking modern design. The sleek stainless steel body is complemented with a choice of two interchangeable black and white base rings.
The iconic Nuki LED indicator on the front quickly communicates key information without requiring a phone at hand.
Universal Cylinder
The premium Universal Cylinder that comes with your Nuki Ultra has the highest industry security class (SKG***) and a drill-resistant body. It comes with 3 physical keys. You can always order new copies with the security card included in the box.
Installing the included Universal Cylinder takes less than 15 minutes, with a visual step-by-step guide in the app. Changing the cylinder doesn’t require any drilling, extra tools, or technical know-how.
Battery
Nuki Smart Lock Ultra is powered by an internal battery, with a single charge lasting for months. You can conveniently recharge your device by simply plugging in the lock with the included magnetic cable directly on the door - or simply charge it off-door overnight.
App and Connectivity
Nuki Ultra has built-in Wi-Fi and Matter over Thread capabilities. You can remotely control your door without an external bridge. Additionally the modern Matter over Thread communications standard, allowing simple integration with a wide range of smart home systems like Google Home, Apple Home, and Amazon Alexa.
Thanks to a new data migration flow, current users can effortlessly move their data (settings, access permissions, and more) from an older Nuki Smart Lock to Nuki Ultra automatically in the app.
Main features
  • 3x faster than previous generations
  • 3x smaller than previous generations
  • Brand new motor and a modern design
  • Stainless steel body with 2 interchangeable base rings in black and white
  • Three locking modes to give users full control:
    1. Insane: Lock/unlock under 1.5 seconds (for double lock action)
    • 3.4x faster than previous generations
    1. Standard: Lock/unlock in 2 seconds (for double lock action)
    • 2.5x faster than previous generations
    1. Gentle: Reduced noise with lower speed (locks/unlocks in 3.3 seconds for double lock action)
    • 1.5x faster than previous generations
  • Bundled with a premium Universal Cylinder for maximum physical security and compatibility with different doors
  • Built-in battery: Can be charged on-door and off-door. Only 2 hours for a full charge, lasting months of operation. Magnetic charging port and cable designed specifically for a simple and safe on-door charging
  • Built-in Wi-Fi and Matter over Thread
  • Simple integration with all major smart home solutions
  • Streamlined data migration for previous Nuki owners
  • Easy DIY installation under 15 minutes and new step-by-step guide in the app
  • Alternative unlocking options are available via Nuki accessories (code, fingerprint, fob, and more)
  • Designed in Austria - Made in Europe
This topic was automatically closed after 1 minute. New replies are no longer allowed.
