After the automatic update from 5.9.4 to 5.10.5, my lock’s MQTT reports got much slower on the default Wi-Fi power mode (Automatic), and the moving states disappeared. Switching to Compatibility fixes it completely, so I’m reporting it in case it affects other Automatic users.
Setup
- Smart Lock Pro (5th gen), firmware 5.10.5, auto-updated from 5.9.4 on 2026-11-18 at 00:01 UTC. Keypad 2 and door sensor paired.
- Built-in Wi-Fi: 2.4 GHz, channel 6, 20 MHz, WPA2-PSK, RSSI about −54 dBm. AP: UniFi U6 Lite, firmware 6.7.57. SSID: DTIM 1, U-APSD off, PMF off, BSS transition off.
- Local MQTT: Mosquitto 2.1.2 on the LAN. Home Assistant uses the lock’s own discovery, so commands go to
nuki/<id>/lockActionwith QoS 2. - The MQTT session is stable: in five days the broker logged reconnects only for the update, one Wi-Fi reassociation and the settings change below.
Before and after the update (Automatic both times)
| 5.9.4 | 5.10.5 | |
Moving state (state 2 / 4) reaches the broker |
0.5–1 s after the command | never |
Final state reaches the broker |
about 2 s | 5–11 s (once 33 s) |
| Action time in the lock’s activity log | median 0.8 s after the command (46 commands) | median 2.5 s (24 commands) |
The first two rows come from Home Assistant’s recorded state changes against the time each command was sent. The last row matches each command to the Nuki Web activity log, which has one-second resolution, so single values are ±1 s.
Trace on 5.10.5, Automatic
Broker-side receive times after Home Assistant published an unlock, 2026-11-23 11:18:11 UTC:
+0.00 s lockAction 1 (from Home Assistant, QoS 2)
+2.20 s timestamp 2026-11-23T11:18:11Z
+3.23 s lockActionEvent 1,172,0,0,0
+5.17 s timestamp 2026-11-23T11:18:14Z
+6.09 s commandResponse 0
+7.12 s state 3
+8.05 s timestamp 2026-11-23T11:18:17Z
The lock command 22 s later went the same way: lockActionEvent at +3.39 s, commandResponse at +5.33 s, state 1 at +6.26 s. Neither published state 2 or state 4. The activity log shows the unlock at 11:18:12, so the motor ran on time and only the reports were late.
Ping from the broker host to the lock during the same period swept from 40 to 930 ms in a steady sawtooth (average 484 ms) with a period of about 1.02 s. So the Wi-Fi seems to wake about once a second, and each MQTT message seems to wait for the next wake before the following one is sent.
Same lock on Compatibility
I switched only the Wi-Fi power mode, at 11:40 UTC, and sent an unlock at 11:42:08 UTC:
+0.23 s timestamp
+0.26 s lockActionEvent 1,172,0,0,0
+0.27 s state 2
+0.36 s timestamp
+1.15 s timestamp
+1.36 s commandResponse 0
+1.36 s state 3
+1.56 s timestamp
Locking was similar: state 4 at +0.18 s, state 1 at +1.43 s. Ping is now 25–115 ms (average 72 ms).
Other observations on Automatic
- An unlock with the lock’s button did publish
state 2beforestate 3. Only MQTT-commanded actions skipped the moving state. - For a lock at 11:13:13 (activity log), Nuki Web’s
updateDatewas 11:13:15.6 UTC, butstate 1reached my broker at 11:13:19.1. The cloud seems to hear about the action before the local broker does.
Questions
- Is Automatic on 5.10.5 meant to wake only about once a second? On 5.9.4 the same setting answered in about 2 s.
- Could the lock publish
state(and the moving state) beforetimestamp,lockActionEventandcommandResponse, as 5.9.4 seemed to? With one message per wake,statearriving fifth costs about 5 s. - Does the MQTT client wait for each QoS acknowledgement before sending the next message? Under power save, that puts a full wake interval between messages.
I’m staying on Compatibility for now. If it helps, I can switch back to Automatic and send a tcpdump from the broker host.
