I am a Smart Hosting customer and I need access to the Advanced API endpoint to create guest invite links programmatically.
Account details:
- Email: h***@gmail.com
- Account ID: 489879406
- Smart Hosting plan (active since May 1, 2026) — we signed up specifically because Smart Hosting was described as the solution to create invite links via API
- Advanced API request submitted: April 23, 2026 (no response received yet)
What I need:
I need to create temporary guest access links (Nuki) via the API so my property management system can automatically send them to guests via WhatsApp before check-in.
What I have tested:
- PUT /smartlock/{id}/auth with OAuth2 token → returns 400 (requires accountUserId, which personal accounts do not have)
- PUT /account/user → returns 200
(sub-user creation works) - PUT /smartlock/{id}/auth/advanced → returns 405 Method Not Allowed
The 405 on /auth/advanced indicates this endpoint is not enabled for my account despite the Smart Hosting subscription.
My questions:
- Is there a separate approval process needed to access /auth/advanced, beyond the Smart Hosting subscription?
- My Advanced API request from April 23 has received no response — can you update me on its status?
- What is the correct API flow to generate a Nuki link programmatically for a temporary guest?
Thank you.
