Yes, same problem as last time. And …
I have installed the brand new 4.2.3 beta this morning and during the day, I noticed a few times that my SL4P was not responding - My Broker also noticed this and I had again to reconfigure the MQTT Connection within the Nuki App: After that everything was fine again for a unknown amount of time.
Will Monitor it and update this Thread accordingly.
root@loxberry:/opt/loxberry# grep Nuki_3 /var/log/mosquitto/mosquitto.log
2024-03-15T13:02:56: Client Nuki_39C748EC already connected, closing old connection.
2024-03-15T13:02:56: New client connected from 192.168.1.103:52434 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-15T13:25:44: Client Nuki_39C748EC has exceeded timeout, disconnecting.
2024-03-15T13:35:46: New client connected from 192.168.1.103:52434 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-15T14:48:26: Client Nuki_39C748EC has exceeded timeout, disconnecting.
2024-03-15T15:46:56: New client connected from 192.168.1.103:52433 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
UniFi WiFi Report:
root@loxberry:/opt/loxberry# grep Nuki_3 /var/log/mosquitto/mosquitto.log 2024-03-15T13:02:56: Client Nuki_39C748EC already connected, closing old connection. 2024-03-15T13:02:56: New client connected from 192.168.1.103:52434 as Nuki_39C748EC (p2, c1, k300, u'loxberry'). 2024-03-15T13:25:44: Client Nuki_39C748EC has exceeded timeout, disconnecting. 2024-03-15T13:35:46: New client connected from 192.168.1.103:52434 as Nuki_39C748EC (p2, c1, k300, u'loxberry'). 2024-03-15T14:48:26: Client Nuki_39C748EC has exceeded timeout, disconnecting. 2024-03-15T15:46:56: New client connected from 192.168.1.103:52433 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-15T16:05:15: Client Nuki_39C748EC already connected, closing old connection.
2024-03-15T16:05:15: New client connected from 192.168.1.103:52434 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
And again:
root@loxberry:/opt/loxberry# grep Nuki /var/log/mosquitto/mosquitto.log
2024-03-15T16:38:32: Client Nuki_39C748EC has exceeded timeout, disconnecting.
Thanks. Please do not send any more updates. From looking at the logs it’s pretty clear why you are seeing the reconnects (and it’s most likely not coming from changes on MQTT side, but the many updates that happened in this build for Matter 1.2 support). This requires an investigation by our team which will not happen over the weekend. ![]()
I have also the issue with fw 4.2.3. It happened, while the lock stops responding to the command from Home Assistant, it executes the command, when I open the Nuki App and keeps working for some time, until it stops again…
The same here
Same issue for me
This morning i got update to 4.24. i Hope that this fw Is able to solve the issue ![]()
How did you install this Version? My Nuki still shows me: 4.2.0 without any Beta
FYI that I have installed firmware 4.2.4 beta on 22.03.2024 and since then I see a bunch reconnects after the Nuki has closed the TCP Connection to the Broker.
root@loxberry:/opt/loxberry# grep -i Nuki /var/log/mosquitto/mosquitto.log
2024-03-19T16:10:59: New client connected from 192.168.1.103:52442 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-19T19:32:02: Client Nuki_39C748EC already connected, closing old connection.
2024-03-19T19:32:02: New client connected from 192.168.1.103:52445 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-19T19:32:53: Client Nuki_39C748EC closed its connection.
2024-03-19T19:32:58: New client connected from 192.168.1.103:52446 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-22T10:41:16: Client Nuki_39C748EC already connected, closing old connection.
2024-03-22T10:41:16: New client connected from 192.168.1.103:52433 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-22T11:06:57: Client Nuki_39C748EC closed its connection.
2024-03-22T11:07:03: New client connected from 192.168.1.103:52435 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-22T11:12:36: Client Nuki_39C748EC closed its connection.
2024-03-22T11:12:42: New client connected from 192.168.1.103:52436 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-22T11:42:25: Client Nuki_39C748EC closed its connection.
2024-03-22T11:42:31: New client connected from 192.168.1.103:52437 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-22T12:02:49: Client Nuki_39C748EC closed its connection.
2024-03-22T12:02:55: New client connected from 192.168.1.103:52438 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-22T12:11:55: Client Nuki_39C748EC closed its connection.
2024-03-22T12:12:01: New client connected from 192.168.1.103:52439 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-22T12:17:35: Client Nuki_39C748EC closed its connection.
2024-03-22T12:17:41: New client connected from 192.168.1.103:52440 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-22T15:44:20: Client Nuki_39C748EC closed its connection.
2024-03-22T15:44:26: New client connected from 192.168.1.103:52441 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-22T16:15:48: Client Nuki_39C748EC closed its connection.
2024-03-22T16:15:54: New client connected from 192.168.1.103:52442 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-22T16:31:32: Client Nuki_39C748EC closed its connection.
2024-03-22T16:31:38: New client connected from 192.168.1.103:52443 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-22T22:02:44: Client Nuki_39C748EC closed its connection.
2024-03-22T22:02:50: New client connected from 192.168.1.103:52444 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-23T10:45:50: Client Nuki_39C748EC closed its connection.
2024-03-23T10:45:56: New client connected from 192.168.1.103:52445 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-23T12:50:19: Client Nuki_39C748EC closed its connection.
2024-03-23T12:50:25: New client connected from 192.168.1.103:52446 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-23T12:55:59: Client Nuki_39C748EC closed its connection.
2024-03-23T12:56:05: New client connected from 192.168.1.103:52447 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-23T13:42:19: Client Nuki_39C748EC closed its connection.
2024-03-23T13:42:25: New client connected from 192.168.1.103:52448 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-23T16:26:29: Client Nuki_39C748EC closed its connection.
2024-03-23T16:26:35: New client connected from 192.168.1.103:52449 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-23T16:45:57: Client Nuki_39C748EC closed its connection.
2024-03-23T16:46:03: New client connected from 192.168.1.103:52450 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-23T16:56:39: Client Nuki_39C748EC closed its connection.
2024-03-23T16:56:45: New client connected from 192.168.1.103:52451 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-23T17:02:29: Client Nuki_39C748EC closed its connection.
2024-03-23T17:02:35: New client connected from 192.168.1.103:52452 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-23T17:09:51: Client Nuki_39C748EC closed its connection.
2024-03-23T17:09:57: New client connected from 192.168.1.103:52453 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-23T17:17:48: Client Nuki_39C748EC closed its connection.
2024-03-23T17:17:54: New client connected from 192.168.1.103:52454 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
2024-03-23T17:28:32: Client Nuki_39C748EC closed its connection.
2024-03-23T17:28:38: New client connected from 192.168.1.103:52455 as Nuki_39C748EC (p2, c1, k300, u'loxberry').
I applyed for the beta firmware program and installed the latest beta. It seems that it is working now with mqtt and homeassistant perfectly.
Same for me. Works with the latest beta since release date.
How many days working without disconnections?
Since 22.03.23 - 16:58
I have the same issue with 4.2.4: at the beginning It works well but after some days the lock doesn’t respond to home assistant. For example this morning i wasn’t able to open the door from home assistant. I opened the nuki app and by moving something in the mqqt section…the lock respond again from home assistant.
This issue Is very annoying.
I used for 10 months nuki 3 pro with mqqt and i havent any issue!!!
I assigned a static ip at the nuki lock in my router and i managed the Power saving from auto to medium.
My mqtt broker Is mosquitto
Help ![]()
I think the same, is very annoying.
Every 3 or 5 days I have the same problems. You can’t trust this lock.
There are many people all over the world waiting for a solution that never comes. This product is not cheap.
Well guys, I’m not affiliated to nuki in any way, but it seems that there is an issue with WiFi/MQTT and Matter integrated. What we all know so far, it does not happen with the 3 Pro. so that’s my logical conclusion. I’m not a developer and I’m sure they do their best and some solutions (if they exist) take time.
From my side the issue seems fixed sind 4.2.4, but I’m not using matter at all.
Keep your heards up, it’s still the best lock I tried, keeping the 3 pro out of the comparrison.
I have Just reset the smart lock and reconfigured from 0. I Will tell if in the next days It Will disconnect from home assistant…
