Siedle VIB 150 Help
Hello everyone,
unfortunately i can’t quite get to grips with the wiring on my Siedle VIB 150. i have attached a picture of how it is currently wired. can you perhaps tell me which cable i have to connect where and how because when i follow the wiring in the app i always get the error that something is not compatible
TaM and TbM are the terminals for the In-Home-Bus. If possible you can measure the voltage there. Please figure out the polarity. In case TaM is the positive terminal you should connect the red cable of the opener to TaM. The black wire of the Opener should be connected to TbM.
In case the polarity is negative you have to swap red and black.
After correct connectivity you should start the configuration flow via App and ignore all the wiring steps.
With this connectivity you should be able to get all features beside the ring suppression.
best regards
Marcel
Following these instructions I reached the point in the configuration, where the ringing should open the door, which it repeatedly did not. Then the Nuki app said, the Siedle might not be compatible. Any suggestions?
