Several SmartLocks connected
I would like to connect several smart locks to each other so that when one smart lock locks, all the others lock as well? And unlock, too.
My alarm system is mechanically activated when the door is locked. I would now like to install a smart lock on 1-2 additional exterior doors. However, this would mean that when a smart lock locks and activates the alarm system, I would have to re-enter the house through the same door so that the alarm system does not trigger when I enter through another door.
@alhu maybe your job?!
Hello Alexander,
If you would like to implement this, I’d ask you to please do so in a fork on GitHub. You can then build and test the desired feature there. Once everything is working correctly, feel free to create a pull request, and I will gladly merge the feature into the main repository.
Best regards,
ALHU
