Rules for keypad codes?
Are there certain rules that must be followed when creating code? For example, if I try to create the code “129999”, I get this response:
{“detailMessage”: “The supplied value ‘129999’ for parameter ‘code’ is not valid”, “stackTrace”:, “suppressedExceptions”:}
If I take the code “139999” occurs:
{“detailMessage”: “The supplied value ‘13’ for parameter ‘type’ is not valid”, “stackTrace”:, “suppressedExceptions”:}
(This feedback is good in principle, since I assume that the code would be created if a keypad were active. Currently I’m still waiting for the keypad, but I wanted to finish the work on the API before).
As it seems to me, the system does not like the succession of “12” only in the first two places, if I use “12” as the last two numbers it works.
I don’t let the security aspect pass completely, because “111111” is also accepted.
Needs to be a 6 digit number. Can not start with “12” and can not contain “0”.
Validation rules level 9000.
Seriously, I guess that my dynamic codes, which would also sometimes start with “12” (e.g. 129417), are quite more secure than “111111”.
But well, then I will take that in mind during the dynamic code creation.
