I’m doing integration with HomeAssistant, and I have some issues:
The RSSI value is related to the Lock-Bridge connection, or the Bridge-WLAN connection? Documentation is not clear about this.
In latest doc I downloaded now (v1.12 - Sep 2, 2020), there’s no indication of the batteryCharging and batteryChargeState attributes provided in /list. I don’t know if it’s the latest doc, I downloaded via official link.
I have a keypad, and in the doc it says that in /list I should find a keypadBatteryCritical attribute, but in my /list output I don’t see this attribute:
Thanks for the notice. It is the latest one (you can always check the online-version for that https://developer.nuki.io/page/nuki-bridge-http-api-1-12/), but in fact the values are still missing. We will add this as soon as possible with the next documentation update
I will try to reproduce this with my test-setup and get back to you.
On my testsetup I get the "keypadBatteryCritical": false,
for the /list request
And your Bridge seems to have the latest FW 2.9.3 running.
So what still could be the issue is an outdated Keypad firmware. Could you check if there is a FW update available for your Keypad (in Keypad management through the Nuki Api)?
I am still not sure what could be the issue (As I assume you also locked once via Keypad (so the keypad battery state had been updated) since the update ).
We rarely use the keypad, it’s an emergency device for us, so I thought it was really a long time we didn’t use it and I just tried it now, and that was it.
I thought Nuki knew it had a keypad associated, even if not used. Does it “forget” the associated devices after a while or it’s just that you need to use them at least once?
The data needed to be sent to the connected Smart Lock one time to be shown, so the issue really seems to have been due to sending no lock command throught the Keypad after the FW-update!
Sorry, I saw your comment but had no time to check in detail what went wrong (bc everything should be up-to-date). Will do as soon as possible and get back to you.
