RIP IFTTT now what?
I have some automations set up in ifttt but since supports drops on Tuesday Im locking for other ways to do these and hoping someone might help.
The first one is when some one opens the door with ring to open (Nuki opener) then it automatically opens my door (nuki smart lock). I often use this for quick errands or quick dog walks where I don’t leave the geofence.
Similarly I have set “lock and go” (smart lock) to activate ring to open (opener) when I leave for one of those short walks.
Any ideas on how to automate this ?
Hello Jesper,
Here is a blog on alternatives for IFTTT for your reference.
Have you already tried Home Assistant for these use cases?
You would need to add the Bridge via the API to the HomeAssistant, of course, connect the Smart Lock & Opener to the Bridge, and then create automations for it.
The first use case should be possible i.e. if ring to open is activated, then smart lock should open/unlock. But the “lock n go” use case is not possible via this method.
I was planning to purchase multiple Nuki Smart Lock Pro because of the available IFTTT integrations.
I will now reconsider.
I would love to learn how I can now send digital keys based on an external calendar directly to my guests without IFTTT or Nuki Smart Hosting…
This question is unrelated to this post.
However, you should use the webhooks & advanced Nuki Web API to create your own code to send automated codes, if you do not wish to use Smart Hosting. Please refer to our Web API documentation for more details.
