I’ve the Nuki Smartlock 3, the Opener and the Bridge, and i’d like to integrate just the Opener with home assistant to receive the notifications and do some automations in it, the thing is that I started with enabling the API in the Bridge and then started to do some tests via Postman and I found that I was able to lock/unlock also the Smartlock with the same token for both devices, so i thought that if add this API Webhook to homeassistant or using the Nuki integration could be a security concern. So I wonder if there is a way to restrict the API or something to just enable access/control the Opener?
