Redesign Battery Power Pack: Better access!
Power Pack
Move the USB-C connector to the front
Instead of two USB-connector that are not reachable and hidden in the back of the Power Pack, you can have ONLY ONE in the front. Then people with reduced motion can eaysier plug the cable.
And you save one USB-C port.
Our Mum barely can have access… and not all USB-C plugs can be used. If they are too wide or have a 90°, they become useless.
By having the TWO usb-C in the back, one has to bend over or go down to try to fit in.
If ONE connector woule be in the front, the user have a perfect access.
way easier to charge the nuki.
someone could even have a usb-c plug at the wall so that when the door is open, it can be chaged.
no more bending over
no more fingelling and trying to fit blindly the pluc
reduce costs (and waste).
EDIT: The world is UBS-C. Why on earth did you introduce now a new type of magnetic cable?
If it would have been because of…“safety”: Have a USB-C on the new NUKIs but sell a cable with magnetic connection. Those who wants it, will pay 20 Euro. The other ones will just have the normal USB-C. And there is always a USB-C around. If the vaccuum robots eats (and destroys) the new cable: no more charging until the new cable is delivered. no way.
