Question about selectively deactivating unlock Google vocal command
Hallo, at That’s how it’s done: Connecting Nuki with Alexa it is stated that, using Alexa to send vocal commands to Nuki smart lock, “You can deactivate in the Alexa App the unlocking of your Nuki Smart Lock via voice command”, that is you can selectively allow Alexa to lock the door but can selectively disable the Alexa Nuki unlock vocal command.
Since I use Google assistant I need to know if the same functionality is available, that is, will I be able to allow Google to lock the door but deactivate the unlock vocal command?
Regards
