Problem opener with bticino 334802
HI. I need help with nuki opener and its connection to a bticino 334802 (8 wires)
First, i don´t know if it is compatible
Second, these are the connections- I think that ports 5 and 6 are bus connections
In 5: brown wire with black wire from the opener
In 6: orange and green from the opener
In the clip: red and yellow wires from opener, and brown-white wire (from original connection nº6)
I can see and hear but the door does not open.
If I press de open button in bticino with Nuki connected, I can open the door. WIthout Nuki connected, does nothing. So I think i have de wires correct connected
Hola! Lo conseguiste al final?
Sí, siguiendo las instrucciones de otro interfono que sí sale en la app, el 334202 (se usan los 7 cables)
Muchísimas gracias! Lo he hecho así, y he tardado 15 minutos.
Graciaas :))))
Hola, tengo el BTICINO 334802 y quisiera saber si el opener funciona hoy en dia con este modelo.´
Saludos
Juan
