Problem creating temporary access
I am testing the Web API for a potential business case in the near future.
I am trying to create temporary access for a user via the Web API and would like to receive a link in the response that can be used to open the lock during the defined validity period.
I have a Smart Lock Go connected to Nuki Web, and I also have Smart Hosting enabled. I can lock and unlock the device via the Web API, and I can create users, but I am unable to create temporary access.
I am running into issues with the code and type parameters.
If I set type to 13 and do not include code field, I receive the error:
“The supplied value ‘null’ for parameter ‘code’ is not valid.”
If I include a valid code (6 digits, not starting with 12, etc.), I receive the error:
“The supplied value ‘13’ for parameter ‘type’ is not valid.”
I do not have a keypad installed on the lock, and I am not intending to use one. My goal is simply to receive a link that can open the lock during the specified validity period.
Am I receiving these errors because I do not have a keypad installed?
If so, is there a type value that can be used without a keypad to generate a time‑limited unlock link?
I’m currently stuck with this and can’t proceed with my development. Is there anyone who can comment on this please?
Hi Erik,
If your smart lock doesn’t have a keypad attached, you’ll need to create an app invite instead. This will create a 9 digit code which the user is able to redeem in the Nuki app to operate the smart lock.
You can achieve this by leaving the “type” as 0 in your smartlockAuth request and omitting the “code”.
Check out page 26 for the section “Invite a User” within the API documentation for further details: Nuki Web API
Kind regards,
Andrew
Hi Andrew
Thank you for your reply. I will check that out.
Does this mean that if I get the keypad, then I can use type 13 and it will work without Nuki App with the pin code or link to open the lock and now it fails because I don’t have the keypad?
Kind Regards,
Erik
Hi Erik,
Correct, with a keypad you will be able to use type 13 and provide 6-digit numeric codes for access. If you only use keypad codes, then your guests/visitors will not need to install the Nuki app.
Kind regards,
Andrew
