from left to right:
white to ERT (for floor call button outside of the bus)
orange to ETb (for floor call button outside of the bus)
green and orange from Opener to TaM
Abschlusswiderstand / terminating resistor between TaM and TbM
black from Opener and white from Siedle-Bus to TbM
red and yellow from Opener and blue from Siedle-Bus into clamp
the blue Siedle-Bus line was at the top TaM before installing the Opener
The intercom does not have to be activated. The open button works whenever I press it at the intercom.
When configuring thru the app the following happens:
pressing the open door button - check
going down to the front door
ring - check
open the door - check
RTO - nothing
So I confirmed anyway that the door has been opened in the last step (even when it has not) to finish the setup and set the delay to 3sec afterwards (as read several times here at the forum)
I can now open the door via the App, but RTO and Auto Unlock do not work reliable
I do not get any notification/protocol entry when somebody rings since then.
thanks that the support team reached out to me on a private message.
Still not found a solution, I noticed a second issue: My video quality of VIB 150-0 gets worse while Nuki Opener is connected to the bus system.
I tried both setups, basic setup and the app guided setup. Issue applies to both.
I gave up as I noticed another issue: My video quality was very bad while Nuki Opener was connected to the bus.
My solution to achieve the same result:
Switched to Nuki Lock Pro to get rid of the
Added Ring Intercom for unlocking the door and talk to people at the door
Having kind of ring-to-open through an Home Assistant automation which is bringing my smartphone location together with Ring and the Siedle doorbell.
Using auto-lock by Nuki only on the floor level
Fur sure, it’s a bit more effort than just connecting the opener. But as the opener was not working properly and the support was slowly, it’s the best solution for my installation.
@Deeder
Nevertheless, please let me know if you have found a solution for VIB 150-0 + Nuki Opener.
Do you also have issues with the video quality when Nuki Opener is connected to the Siedle bus?
