Play a sound when unlock
Nuki Lock
Enable a feature where you can be informed that the lock is opening while your eg listen to music on your EarPods
If it’s switched on in your settings you hear a sound or it is indicated with vibration
Sometimes I stand in the front door and push and push and wait till the smartlock has unlocked the door
There would be a audio, visual or haptic feedback that the door is gonna be opend
I like the Idea of an audiovisual and indicator.
I would suggest another Device, perhaps looking like the “Nuki Button” (also in different designs!) which acts as a Status indicator, paired with the SmartLock.
Something like:
  • Green light + positive chime (like low and high tone): Code accepted / Smartlock unlocked (and latch opened)
  • Red light + buzz : Code not accepted, Lock not unlocked
  • Blue light + positive reversed chime (like high and low tone): SmartLock succesfully locked.
For me it is important to have something while I use my phone for something else.
Another device is I have to pay money for it.
If it’s in the app - it’s for free.
Maybe a two step approach
Hey @FloGro !
Maybe I’m not getting suggestion well enough, but if :
  • you allow your notifications for the Nuki app on your phone (with sound notifications allowed)
  • in the Nuki app settings you set it to notify you when the door is unlocked
Doesn’t that solve the issue? Or do you mean that you want it to play on the lock itself, or some other way?
Cheers,
David
I think the problem is a tiny delay of the notifications. When you set the unlock time to 3 seconds, it sometimes takes longer to get the notification and the door is already closed again.
But I also think that would make it difficult in general to implement such a thing. As long as the phone isn’t connected directly via Bluetooth, there could always be a delay in the communication between SmartLock / Opener and the app, which is longer than the unlock duration.
Thank you for the clarification.
I agree, that would probably be something rather on the unfeasible side in that case. Some delay between that and the notification is inevitable due to the travel time between the servers.
One solution could be to setup API monitoring on your own server and maybe you could increase the rate (as compared to IFTTT for example), but I’m not sure the effort is worth it only for this consideration.
