Pair keypad without google location services?
Hi, i want to connect my keypad with my lock 3.0 via the app. But starting the setup dialog asks me to enable google location services which I don’t want and which this process should not need either.
Setting up the door sensor made this pop up too and selecting ‘no thanks’ was honored there. But not when trying to set up the keypad, the setup flow just doesn’t advance.
I have location, Bluetooth and WiFi enabled which should be all it needs, what can I do if it still doesn’t seem to be (without enabling ‘google location services’)?
Hi! It’s a late response, but you could grant the permission on setup, and after successfully setup, you go to apps in the android settings, choose the app, choose permissions, and deactivate the permissions again, what you not want!
