Is it possible to open a smartlock with just a direct url from a webbrowser ?
I looked at https://developer.nuki.io/page/nuki-web-api-1-4/3/ but I am not sure…
thanks a lot
Luc
thanks a lot
Luc
Yes and no.
Section 4.1 has the example that details what needs to be called: https://developer.nuki.io/page/nuki-web-api-1-4/3/#heading--curl-call-swagger
But you can’t do this in a GET request (= a simple URL call from a browser) and you won’t do it, because it is normally called server side in a php script or similar.
If you want something simple without any technical skills have a look at what you can do with IFTTT: IFTTT - Automate business & home & e.g. Button widget Integrations - Connect Your Apps with IFTTT
Thanks you for your prompt response.
Even with IFTTT, it will not be a simple url, but a button on the smartphone homepage to be installed. Am I correct ?
So the solution would be to install the POST request on a web server PHP page, to be executed on the page loading. Right ?
Thanks alot
Yes & Yes
Hi Luc,
by any chance were you able to create a script? I am very interested in this feature. Thank you
No, sorry. I was just checking the faisibility.
You need a webserver to run the script.
ok thanks, i will try on my webserver
