Hi there,
I tried to install the opener with the instructions for the Siedle HT 611-01 but it doesn‘t work. How do I connect the opener with the ZGO 611-0? Any advice on how to connect them?
Cheers
Chris
Hi there,
Cheers
Chris
I have the same Siedle but also no doors open by Nuki.
Did you receive a solution from Nuki or others?
I have the same setting, but ring to open doesn’t work ![]()
There were no cable in 7 and I don’t know how to wire the Nuki yello cable.
Any advice?
I figured out how it works!
“A” and “G” are to different bells (in my case A is the bell in front of my apartement door and G is the bell of the front door).
If you figured out which one is the right one, just follow the Nuki instructions but use A ore G instead of 7.
So in the end, one of the wires are connected with the yello NUKI cable and the green NUKI cable is connected to “empty” A ore G.
Hope my findings also helps others ![]()
Hi Lino, thank you.
I have a HT611-01 with a ZER611-01 modul.
The Zer611 only have A, c and D.
A is connected to 2 wires and c also (one goes from c to 6.1 from the HT.
But in the Opener Instructions theres no meaning for the yellow wire, just blue, violet, orange, black, red and green.
I will try it, and post my result here.
@Calibrator87 did you get it to work? I have a ZER 622-0 which seems to be similar and I have no idea how to wire the Nuki
I stopped trying now with Nuki (their support couldn’t help also) and switched over to Shelly Uni…
