Opener works with ritto 4816/02
I have an ritto 4816/02 twinbus (Video). I selected and wired it as instructed for ritto 4630. it worked right away, so you might consider to add it to the list if compatible devices.
The most challenging part was to keep away the heavy screen while installation. I managed it by using a little rope and tie the video screen with this rope to the wall mount using the hikes in both parts during installation. Ideally a second person holds the screen while installing the cables…
Let me know in case you need more info
BR
I have just done the same and can confirm that it’s working well.
Only difference from the instructions was that I had 2 cables connected to the “A” slot instead of one.
I have an 4816/02 written on one board with the a b and (item number the hole thing is 4816.72)
But the Nuki app with configuration “4630 (Beta)” give me the error “unusual configuration”.
I tried also the Generic / Generic Twinbus profile…
Which 2 cables did you connect to the A slot? :thinking:
