Opener with elvox 6304 digibus
hello, my video intercom is the elvox 6304. It is not listed as supported model. I have already writted to the support but the answer was a generic “try with a generic intercom”, even if I send them the cabling schema.
This is the current situation
and this is the schema reported in the elvox manual
The cables are connected in position 1,3,4,5,7,8,10 according to the schema.
Can you please help me and try to suggest how to connect the opener?
Thanks in advance
Hi! Please try this, - Take the nuki-clamp (the two port clamp what comes with the opener) and do the red&yellow opener wires together in one port of this clamp, now unscrew the red wire on block-1 and do it in the second port of the clamp, now screw the orange&green opener wires on block-1 of the intercom, first wiring try finish! Now reset the opener, and do a fresh setup, and choose generic bus as intercom! Let me know how it goes!
thank you Rose, I will try your solution as soon as I will be at home.
:+1: let me know how it goes!
Hi! Any progress?
hi, not at home yet…
Hi, I’ve the same issue. Could I know if It works? Thanks
