Opener with Elvox 5601
Hello comunity!
I have a video intercom Elvox 5601/000 and it is not listed as supported model for the nuki opener. I wanted to check if someone could help me figure out what is the best way to connect the Nuki Door Opener to this current setup. Here is a picture of the existing connections. Also I’ve tried to find on the web some terminal diagram to label my connections but not with luck. The only thing I found was this scheme. Any expert electrician to help me set this up?
The connected terminals are:
1, 2, 3, 5, 6, 8, 9, 10, 11, 12
Thank you in advance!
