Hey,
I have had my opener for a while but can never get ring to open to work right. Unlock works fine.
My handset is Cometil - unknown
My solution so far has been to take a feed off a notification led. The issue with this is, the opener only detects once’s the LED has gone off which happens at the end of the call.
I thought if I wire the green cable into the call speaker that would work as it’s only active as the caller presses the call button.
Does anyone have any suggestions?
