I’m trying to install the Nuki Opener on the Urmet 1132-D005C intercom.
I found the model “1132” in the app but not this specific variation.
I have only two wires coming from the wall connected to the unit. There is a port which connects the circuit board to the headset. There are no other ports from which one can remove wires.
The app instructions mention to remove the “port CA” – I can’t see this anywhere.
With this intercom, one must ring the bell and the handset much be lifted before the door can be opened.
I tried both of the following options but none appear to work. I get the messages “The installation of your intercom system does not comply with the standard”
Option A)
Putting cable (+) into the clamp
Putting red and yellow cables into the clamp
Putting green and orange cable in the (+) position
Option B)
Putting cable (0) into the clamp
Putting green and orange cable in the (0) position
