Hello!
I am looking for a solution how to controll our new door with electronic lock. Unfortunately we did not integrated the Nuki Button so now I hope for a workaround.
The lock is driven by the Siegenia KFV60-24-1 AC-DC.
The idea is to use the Nuki Opener to act as a switch for the lock and the Keypad 2 for access.
this will work. Just use the Opener with blue and purple cable. You can configure the Opner as Gate. Which KFV Lock do you have? Is an input signal available? KFV60-24-1 AC-DC is the power unit.
This is great, thank you Marcel. What ist the switch based on? Relay or MOSFET?
Is it then possible to configure the duration of the impulse if necessary?
Is it possible to attached the opener to a permanent USB power supply?
Unfortunately I don’t have the specific lock model, I will try to find out.
