I’m just about to hook up both. I’m curious if this will work with the loudspeaker because I don’t want to connect the original loudspeaker anymore and only want to have it ringing and ton through the opener.
Edit:
Do I currently have a chance to test the microphone connection?
I have connected the red and black cable from the opener to the speaker output of the Gira ring. Where the original speaker was connected. If someone rang the bell, I can’t hear what they’re saying. Shouldn’t the speech sound be output via the opener?
As i wrote above, this is currently not available in the firmware. You can (currently) not replace your intercoms loudspeaker or mic with the Nuki Opener.
Hello Jürgen, thanks for the answer. I have misunderstood you and have assumed that the loudspeaker can already take over the voice output technically/analogue.
Without the firmware being adapted for an app solution.
But after my tests I suspected what you have confirmed today.
But that’s not too bad, I have now everything ready on my Gira bell for a future functional expansion of the opener and look forward to your update sometime.
You say “currently” Will it support listen & talk functionality anytime soon? I’d buy this product for sure if I could use it for listening, talk and open the street door from my attic!
Do you have some updates on it? I’m also trying to find some solution to replace my legacy intercom with some smart solution and I want to have the ability to talk & listen & open the door through my iPhone.
When I first read this I got really excited about the potential upcoming firmware update. Then I noticed that it was announced on 2020 and realized this is quite stall.
