Dear Nuki Team and Community,
yesterday I have successfully connected my Opener (FW 1.4.4) to our Ritto 6111 door system (a pretty old 4 wire analogue system). After studying the available schematics from Ritto and Nuki, I connected the System as follows:
Ritto - Nuki - Comment
1 - Purple (GND) - common ground of door opener and ring signal (0V)
3 - Blue (OPEN) - door opener signal (50V)
4/D - Green (RING DETECT OUTPUT)
formerly 4/D cable - Yellow (RING DETECT INPUT)
Comments:
- We are not using the 4/D pin at all because of the horrible sound. Instead, we have connected a triad gong between “1” and the cable formerly connected to 4/D, now the green one from Nuki. But it should work as written above!
- Once you press a door station button after a ring came in, the Nuki will not work anymore as the door station will be in another mode. Wait until you opened the door using the door station opener button, then Nuki can take over control again
- The opener works with the ring signal coming from downstairs, the “horrible” ring sound. It does not detect the slightly nicer “Tonruf” signal from the ring button next to your apartment door. It’s the nicer signal, but maybe too weak. Doesn’t matter as I want to open the building door downstairs.
So the Ritto 6111 can now be added to the compatibility list with the cabling schema from above.
Best,
Torben
