Conseguiste hacerlo funcionar?
Gracias por adelantado
Everything worked except for ring suppression. Now itās deinstalled and laying in a drawer. Not willing to waste more time with this product.
Por favor echame una mano, tengo el fermax 3314 y no soy capaz de configurarlo⦠Pago por el asesoramientoā¦
I also donāt understand this, the Nuki people are really good and helpful, but with the help for wiring they have a real issue, - I myself had now and in the past, contacts to several users what where in contact with the support for wiring, with the outcome "it doesnāt work, and should send back, for refund ", but I was still able to help the most of them where I had contact, - at least 10 people, I helped to wire the opener with all functions, where nuki said, sorry not possible before!?
Hi. How have you managed to get it working?
I have a Fermax 5601 and connected the wires as in the guide:
L cable to one side of the clamp. Yellow and red to the other side
Black to -
Green and orange to L at the fermax
The bell is not ringing and I cant open the door with the fermax any more.
Normally I had to press the speak button and then the open button to open the door
But now the speak button is not working any more.
I also tried to ring bevor as you said. But neither the fermax nor the opener recognized it (no ringing)
EDIT:
Iāve done more testing today.
I tried the Fermax 5601 setting, the iloft telephone vds extra (which I guess is the same?) and the Generic VDS setting
For the wiring I tried as here posted:
Red, Orang and Green - L intercom
L Cable - Clamp
Yellow - Clamp
Black - Minus (-)
and as desribed above the wiring explained in the Guide at the app
The failure is always the same ā I can open my door normally without ringing outside, I have to press the speak button. The the LED at the button lights and then I can press the open button.
When Nuki opener is installed the speak button is not working any more, the lead does not light on and only a ābeepā is outputed. The door open button afterwards is also not possible.
Iāve also tried to activate the debug mode so catch some logs. But no matter what I tried, no log was displayed.
Wow, this really helped! Thanks!
hola, conseguiste algo?
