Hi everyone,
Does any of you have the Opener installed in a Golmar T810? I’m not sure if it is compatible.
Thanks in advance
Hi everyone,
Thanks in advance
Hi there!
I just installed Nuki on the Golmar T810 and its the exact same instructions as for the M-500. You can follow that instruction and it works fine!
Hi Stefan,
Thank you so much for your help!
I will receive mine this week and will follow your advice
Hi Stefan,
Where are the instructions for the M-500? Can’t seem to locate it.
Thanks!
Hallo Marco can you give us an update if the Opener worked with your Golamar T810 and possibly how you connected the system?
