After installing following this instruction my Bticino is not working even without the Nuki Opener. I’ve tried with another one and The same thing happens. Any idea what’s going on?
Hi!
Yesterday we got our new bticino Intercom (bus 2 wire - 344682) and I was trying to configure the opener with it. It seems to work, but when I will press the eye button to activate the camera, Nuki will ring :o. Any idea what the problem could be?
Thanks in advance
kind regards
Stephan
I now have opener and bridge.
I tried the wiring of @spn above as well as the simple bus wiring.
In the app I chose Generic (BtiCino). I do “can open without ring” and then when it tells me to click “open”, then I click and the app recognizes.
BUT - it still does not work. when I am down (5 stories), i send the command but nothing further happens ![]()
Any thoughts?
edit: would be nice if someone could also share their settings in the app.
Do you find a solution ?
no
@photomichl :
Thanks you so much. I was already in despair. Found the first one in several sources but never got it working. Second one worked in the first try!
@photomichl :
Agree with Markus; Thanks Michael!
Using your “working” diagram my Nuki Opner now works with Bticino Classe100 X16E (344682 - 344782 - 344932 - 344786). Even so this model has already build in WIFI it does not support and has no app for the Apple watch so the Nuki opner was the perfect solution.
During the nuki setup process I selected:
Generic: bticino bus (beta)
Can you open the front door without ringing the bell first > Yes
Can you open the door by pressing the door opener > No
