I installed my new Opener today with my Ritto 7630/x0.
Everything seems to have worked, opening the buzzer, opening automatically after ringing etc.
But after installing my Opener the bell did not ring anymore. After checking and double-checking all cables and connections I couldn’t find anything unusual and I couldn’t make it work.
What’s important to note is that the LED still blinks when somebody pushes the button, opening works etc. - it‘s just the bell that does not ring.
I ended up reversing the process and unfortunately it still doesn’t work. I assume that I‘ve broken some cable or something on the board when installing it.
So my question is more about a replacement unit than it is about the Opener. I hope to find some answers here, since the Ritto intercom is pretty widely used.
- are there any things I can try to make it work again?
- can i just buy a replacement or does it have to be replaced by a professional?
- does the replacement have to be an exact match in terms of the model number? The 1763070 is available on amazon. Are they compatible?
Thanks a lot!
