Open Nuki with a relay close contact
Product name : On Fob, Bridge, Smart-Lock, or an all
Add two electrical contacts, via two screw terminals, normally covered by some plastic, to Fob, Bridge, Smart-Lock, or to all. If you shortcut these two contacts with a relay, the Smart-Lock should open.
This is much more easy than to dis-assemble a Fob and find some wires to do the job.
There are many door-systems out, which provide a relay contact for a door-opener. It would be perfect, if the Nuki world could make use of these relays. By any means.
Connect to door intercom systems
Alternatively, a new device like the Fob could be developed here, which has a digital input.
I have currently also disassembled the Fob to connect Nuki with my fingerprint which is built into the door frame
