Hello. As the title says. Nuki works just fine, but I cannot open from outside using the key… it looks like the key does not fully fit… any ideas? I am considering returning it. It is a v1.0 by the way. Thanks.
That’s not the problem of your nuki, but the problem of your lock. You need to have what we call in the Netherlands (cylinder slot met paniek/hotel function.) lock with panic/hotel function. I don’t know how it’s called in other country’s
Right, i can imagine it is some sort of compatibility problem. OK, so I will be returning it then. Thank you.
It is easy to get a new lock and replace it if you have the keycode on the key or card. But it is expensive.
