just got my Nuki Ultra (Germany) but unfortunately the outdoor side is too long. The cylinder only provides 30, 35 and 40mm length and with 30mm it stands out about 4-5mm.
Will there be any other cylinder in the future or any options for me without changing the door? Otherwise I would have to downgrade to my 3.0 pro again
Taking the old cylinder is not a good idea, as it will then lack the screw to attach the mounting plate. A different door fitting may help. The one pictured is 15mm thick on the outside, if your old fitting was 10mm you have the missing 5mm. Or contact the manufacturer of the Nuki cylinder M&C, who also offer other cylinders.
So? The old Nuki locks have been taped to the door for years and now it is suppose to be a problem? Yes, of course, it would have been great if Nuki technicians/designers would not have been stupid and the mounting plate would just fit to the screws of the rosette. But why think about those easy things, if you could just claim to bring out another lock to fit persisting cylinders?
Using the old cylinder, cutting off the key and taping Nuki to the door works just fine, if one wants to go down this road.
Thanks for your reply.
I also contacted the manufacturer and got this reply:
âIf it is the side of the cylinder with the key insertion, the standard 30 mm is the length. This side of the cylinder cannot be shortened.â
Guess I will send the Ultra back and keep using my 3.0 Pro again :-/
When you turn the key, you see which part doesnât move. Mark that spot with a pen. That is the center of rotation. Then cut the key symmetrically from there.
I havenât been able to get my hands on a ultra yet as they are sold out. But that is how I plan to do it.
