Nuki Smart Lock Ultra Nordics Useless in Home Assistant
I integrated the lock in HA with Matter went fine it seems fully integrated .
But when i activate unlock it immediately turns back to locked state without locking and after a short while it convinces the nuki app that it is locked even tho it is still unlocked. that is absolutely not ok. It is the same with zigbee and google home.
edit it works fine with the nuki app by itself except i can’t get it to auto lock
Just to get this right: You are not able to unlock the door by using the Matter integration but via Nuki App or button on the device it works. Correct?
Can you lock it via Matter, if you set it manually to unlocked before?
Do you have a knob/bar or handle on the outside of your door?
(i.e. do you use the unlock or “open door” command in the Nuki App to enter from the outside)
I am able to unlock but the slider in HA goes back up to lock state. like in this video.
https://www.youtube.com/@kenneth9502/shorts
yes if i unlock the door via the nuki app i can lock in HA
No i do not use “open door”
https://www.youtube.com/watch?v=O4THLelMiCk
This video shows when i unlock in HA it goes back to locked state and the nuki app does not registre that it is unlocked . and when i unlock with the nuki app HA registre the unlock but goes right back in lock state and after a short while the nuki app nuki app also goes to lock state even tho it is still unlocked .
bumping the topic . i still haven`t got it to work
I have the same issue just like in the videos from @hitme . I installed my nuki today, and I’m running home assistant 2026.7.1 (latest as of today). Locking and unlocking works from HA using the lock.unlock and lock.lock services, it’s just the state that is reporting incorrectly, and like hitme I also observed the app screwing the state up as well, which makes me think it’s not (only) the matter over thread integration to HA.
I’ve tried recalibration which seemed to fix the state in the app, but not in HA, and after fiddling around with the services in HA it seems like the app gets confused as well…
I have the same issue as @hitme, the lock status in my Apple Home app is always locked, even though the lock is physically unlocked. Initially I think it’s the Matter integration that caused the issue, but removing my Nuki Smart Lock Ultra Nordics from my Home app doesn’t fix the issue.
Found a workaround on Reddit: https://www.reddit.com/r/Nuki/comments/1qzh1fs/comment/o6ez4cx/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
As he said, Nuki doesn’t turn far enough to recognize the “unlocked” position even though the physical lock is unlocked. In my case I’m using an ASSA 2000 lock so I moved the unlock slider all the way to the left and it does fix my issue. Still, I agree with the original reddit post as this should be fixed in the firmware.
